3ds Max Autodesk 3ds Max
Old October 4th, 2006   #1 (permalink)
jccloutier's Avatar
Default UV map on non-orthagonal multiple objects imported from ADT
when you import multiple objects into max that are not simply square (have sides that do not fall within the xyz planes) such as these columns,
1. how do i uv map the cylinders with a cyindrical map without exploding the objects and applying the uv map individually to each cylinder (there are hundreds)?
and similarly,
2. how do i apply uv maps to the green diamond shapes so that the map is parallel to each face (including the 45 deg ones) without exploding the objects and applying the uv map individually to each diamond?
jccloutier is offline
Old October 4th, 2006   #2 (permalink)
abicalho's Avatar
Default Re: UV map on non-orthagonal multiple objects imported from ADT
Try using Mapscaler. It sets the UV paralel to the face so it should get you closer to what you want.
Alex Bicalho
abicalho is offline
Old October 5th, 2006   #3 (permalink)
jccloutier's Avatar
genius. easiest solution ever. works perfectly, thanks.
ADT objects not cutting Sawyer AutoCAD/AutoCAD Architecture 2 March 1st, 2006 02:27 PM
Exporting ADT linked objects as 3DS fernando-1 Autodesk VIZ 4 September 22nd, 2005 10:08 AM
ADT objects in 3D Max gigi_gi General Discussions 4 April 24th, 2005 07:53 AM
which fileformats support multiple map channels? oluv 3ds Max 1 November 2nd, 2004 08:23 AM
affecting ADT objects in max. opus13 3ds Max 0 November 1st, 2004 09:14 AM
