Thread: Max 64bit
Old February 26th, 2008   #2 (permalink)
lambros
lambros's Avatar
Name: Lambros Potamianos
Greece
Default Re: Max 64bit
everything works ok, don't worry. Max files can be loaded and saved with no problem between 32 and 64 bit versions. You will have to install the 64bit vray to benefit from the new architecture though.
I use Vista 64 and all of my major software works ok (max, vray, maxwell, fry, Photoshop CS3, After FX CS3). Only my Logitech setpoint 64bit drivers seem to cause some problems from time to time (which is inexplicable since they are 64bit) and I know that if you try to install previous versions of Autocad (2006-2007) they will notify you about incompatibility but they will run fine.
lambros is offline   Reply With Quote
