Go Back   CGarchitect.com > 3D SOFTWARE > Lightwave
Lightwave Lightwave
Old October 5th, 2006   #1 (permalink)
warprat's Avatar
Malaysia  Send a message via Yahoo to warprat
Default UV mapping
Heloo everybody kinda quite lately....... well I would just like to ask about UV mapping. whether u guys use this technique in your work. I am asking cos I just managed to get my head around the idea (duh!) and I found that I could get great results plus a lot more control over details. So I was wondering if anybody else uses UV mapping in Arch visualisation? I have attached a render of a clock I done lately nothing to do with arch vis but just a asmall test with UV mapping.
Looking forward to hearing from u guys.
Cheers...........
warprat is offline
Old October 6th, 2006   #2 (permalink)
IC
IC's Avatar
Scotland
Default Re: UV mapping
Yeah I use it but very rarely in standard arch viz work. Sometimes furniture modelling requires it but even complicated stuff can often be done with standard mapping.
Nice clock face you got there. I was working on one recently. Texturing all done with planar and cubic mapping (yet another unfinished project!).
http://iainc.carbonmade.com/
IC is offline
Old October 6th, 2006   #3 (permalink)
Name: Florian v. Behr
Germany Send a message via ICQ to Limbus Send a message via Skype™ to Limbus
I use it mostly for baking textures. Most other Stuff can be done with the standard mapping methods.
Florian
www.florianvonbehr.de
Limbus is offline
Old October 7th, 2006   #4 (permalink)
warprat's Avatar
Thanks for your input guys.
I've been thinking , and what I notice is that for the resolution being at 1000 x 1000 that makes the mapping look good. compared to what I used to do was just take any size of image and slap it on my object. whick would result in a blurry looking final render. I remember a post some time ago where we discussed about mapping resolution. It's just I have really been looking in to my texturing and mapping skills lately, and I have been noticing stuff where I went wrong or my render just did not hit the spot. Sometimes I use Screen grabs for texturing which can also give quite a good render, what do you thing about that method?
cheers...
warprat is offline
Old October 9th, 2006   #5 (permalink)
IC
IC's Avatar
Scotland
Screen grabs of what?
Basically the larger your texture map the better the final output but if the image is blurry or distorted, size won't matter.
IC is offline
Old October 11th, 2006   #6 (permalink)
Malaysia
Yes, I use it all the time.
It is very useful when you have to copy elements (such as background trees) many times within one object. No need to map each one separately.
thinice is offline
texture mapping missing!!! mesht Maxwell Render 5 August 3rd, 2006 10:44 AM
Camera per pixel mapping enigma 3ds Max 0 January 4th, 2006 10:09 AM
texture mapping dnagi 3ds Max 5 September 22nd, 2005 07:38 AM
UVW mapping question. salf 3ds Max 3 July 15th, 2005 01:40 PM
mapping gizmo transformation !!?? virses 3ds Max 1 September 21st, 2004 05:07 AM
