Name: Patricio Silva |
Hi
I'm trying to model some curved walls. Here's what I've done: - Curved line - Extrude modifier to give height - Edit Mesh - extrude do give some deph The problem is that suface is only visible from one side as you can see in the attached picture. Some help?? My objective was to get a wall which is curved in horizontal and vertical (should be something like a "spherical modifier" to a plan surface), but i gess that is only possible moving vertexes with edit mesh. Thanks, Best Regards |
Name: Luke Cottle |
I agree with the shell modifier, alternatively you could draw the full outline of your wall and extrude that.
The problem you have is normals on that backwall, which you could easily flip to solve the problem (have a play with the normals modifier) |
| Need help with walls | 3darchitect | 3ds Max | 4 | July 21st, 2006 03:00 PM |
| Walls & Dims | Sawyer | Autodesk Revit | 12 | March 24th, 2006 10:05 PM |
| how to place windows in curved walls??!! | Aspiring Visualizer! | AutoCAD/AutoCAD Architecture | 1 | August 19th, 2005 12:59 AM |
| Mapping a curved road | rcase | 3ds Max | 4 | April 10th, 2005 03:16 AM |
| crazy walls? attaching emselves anywhere..... | kingeldar | AutoCAD/AutoCAD Architecture | 17 | April 26th, 2004 10:07 AM |
