Old February 28th, 2008   #6 (permalink)
daveb867
Default Re: Sky bitmap with daylight system
also i am having difficulty getting my head around altering the settings of the daylight system so that the sun intensity, position etc matches that of the sky bitmap, if i use a sunset bitmap, would i need to reduce intensity (mulitplier) of sun and sky and obviously the time, and would i need to alter exposure control settings to accommodate
how do you guys go about this??
eventually i want to render out various images of the same building at different times of the day but i want to use sky images as the sky rather than the physical sky. i also want it to look as photorealistic as possible.
what are your general workflows for this kind of process?
