Old February 29th, 2008   #14 (permalink)
Tommy Burns
Ireland
Default Re: i am loosing it...
A couple of things I've noticed have only done a few int renderings with mr but I always got good lighting. First I would say is I always use FG at Draft standard setting maybe Low but never medium must take ages to render.
Not to sure on this but you have Read/Write and Read only ticked. I would usually do a test render with none of these ticked so I am getting no saved settings in FG.(I think this is your main problem) Then if it's right I would use the read write option to speed up the main render. Also I would use photon radius this seems to help. I change physical scale to Unitless and enter 90,000 and use a preset in PH.exposure control. Could be a bit off on some of these but I nearly always get great results with these settings. Let us know how you get on?
Tommy Burns is offline   Reply With Quote
