Old February 29th, 2008   #21 (permalink)
xeunox
South Africa
Default Re: i am loosing it...
try calculating fg on draft, on a a4 of 72dpi, and then on 300dpi, using a semi complex to complex scene and you'll see why. i do it for render speed, but also so keep the correct size of the fg solution on a larger scale with very little change in quality
xeunox is offline   Reply With Quote
