Old February 29th, 2008   #30 (permalink)
Justin Hunt
Justin Hunt's Avatar
Default Re: i am loosing it...
You can render two different camera angles to the same FGM, as long as they are in different possisions. The photon map is view independant so you only need to calculate it once for both cameras, so long as the are no changes in the scene.
The grainyness could be down to either low AO samples or low reflection glossie samples.
One a side note check the scale of the people, they are huge.
JHV
