#11 (permalink) |
Name: Valarie Harris |
You can enable rpc shadows. Click the "mass edit" button under "RPC Edit Tools". Be warned though, rpcs are 2d objects so you will not get the best results when it comes to shadows. There are some ways to overcome this by faking in shadows. You can make your own shadows by applying a shadow image with an opacity map to a plane placed just above the ground or you can cast shadows from a 3D object that is not visible to the camera. 3DAS had a good example of this in their 2nd tutorial. Here's the link if you are not familiar with their weekly tutorials posted here at cga. http://www.cgarchitect.com/upclose/VI/default.asp
#12 (permalink) | |
Name: Caleb Bastion |
Go to your direct light or sun which ever you are wanting to get a shadow from, hide everything else except what you want to shadow render out a nice big image. Save it as a TGA with a alpha split. Go to photoshop and invert the alpha split so black becomes white and white becomes black (you can delete the none alpha image). Then put this map in your material editor in a slot that you can leave it there. Go to the sun or light then modify list then advanced effects. Click on projector map search in your material editor and click the shadow map and make it an intance. Then you make everything that you just created a shadow from not project shadows and there you have it and nice shadow. This is also great if you have a lot of plants and want to cut down the rendering time as you have turned shadows off on a lot of objects. Only prob with this is if there is an object thats in the path of the shadow it will project on the object so go to photo shop and delete that shadow. Which works out fine because if there is an object in the way this means what ever shadow required there will already be shadowed by the object. Not sure how much sense that makes but hope that helps CookiE |
#13 (permalink) |
Name: Jose Luis Ayuso |
yes, I used times ago, was nice but i think that now is not practical need so
much ram memory. Hellow, is my first post and i am happy. |
| tip: changing the color of RPC cars | plastic | Tips, Techniques and Frequently Asked Questions | 33 | September 24th, 2007 09:42 PM |
| Good RPC Tree Shadows (Without Projector Maps) | tmccarter | 3ds Max | 0 | May 6th, 2006 03:22 PM |
| questions about RPC stuff... | upshot | General Discussions | 4 | November 2nd, 2004 11:34 AM |
| rpc problems..sorry for wrong posting earlier | haneet khanna | 3ds Max | 3 | May 30th, 2004 07:59 AM |
| rpc problems | haneet khanna | 3ds Max | 1 | May 9th, 2004 09:54 AM |
