Correct; this is by design (although you could question the design
Photons either reflect "glossily" or "specularly". Only "specular" photons contribute to caustics, only "diffuse" and "glossy" photons contribute to global illumination.
The A&D material treats any glossiness above 0.5 as "specular" for photons, and anything less as "glossy". Hence, it will
not propagate caustics for glossiness 0.5 r less.
/Z
Originally Posted by AJLynn
With apologies to Jeff Patton, see attachments (Max08 file). I was messing around with an oversimplified version of a space I'm working on to experiment with some settings and exposure control, and I wanted to bounce a caustic off the floor. Used the Satin Varnished Wood preset, and started getting this sort of crap:
and a very slow photon map calculation with no apparent caustics.
Long story short, after some experimenting, for different values of the reflection glossiness on the wood floor:
0.51 and over produce the expected effect
0.5 and under produce the error
WTH is so special about glossiness=0.5? I would think that any reflection glossiness should be able to produce a caustic of whatever blurriness.
