Old October 10th, 2006   #1 (permalink)
Andrew1's Avatar
Lightbulb Vray Reflection Problem
Hi Guy's,
I have been recently working in spare time on personal project testing light and hdri reflections.
Now at work we have both version of vray 1.5 rc2 and 1.47,
I have got myself stuck without any conclusion regarding the differences in reflection with both versions.
All the material setting are the same, render settings are the same light setup is also the same on both renders.
Notice jaggedy edges with vray 1.5 rc2 on the left side of the speaker,
where with 1.47 there are hardly any.
I have tried to mess with interpolation settings in the material rollout, no results, checked antialiasing with several different settings, still that's no the problem. Have tried several different gi engines and no reluslts.
This is strange I can not eliminate the jaggedy edges in vray 1.5,
Anyone got any ideas regarding this issue that would be great.
Hope someone can help
Andrew
Yo ! Let's Pimp this up Gee !
Andrew1 is offline
Old October 10th, 2006   #2 (permalink)
Hao La's Avatar
Default Re: Vray Reflection Problem
Did you check the color mapping tab?
Hao La is offline
Old October 11th, 2006   #3 (permalink)
kippu's Avatar
sub pixel mapping , in the color mapping roll out ...that will fix it
www.renderviz.com
kippu is offline
Old October 11th, 2006   #4 (permalink)
Name: sehul limdiwala
hi,
this is sehul. thanks to all members os cgark. i m realy hapy 2 join this group. i want 2 know dt what is easy way 2 creat a carving design in 3ds max. please give me reply becose i m confuse at 1 place.
sehul_2005 is offline
Old October 11th, 2006   #5 (permalink)
Andrew1's Avatar
Thank you for your quick answer,
I will check this out asap, just wondering why in vray 1.47 this was not an issue and here in 1.5 I have to check sub-pixel mapping...
Thanks !
Andrew
Andrew1 is offline
Old October 11th, 2006   #6 (permalink)
kippu's Avatar
well i dont know why they made it a separate option coz i switch it on all the time .. supposedly that option was always "on" in 1.47
from the help manual
"In V-Ray 1.5, the default value for both the Subpixel mapping and Clamp output options is off. While this produces more correct renderings, you may get isolated bright dots caused by reflective or refractive caustics that did not appear with previous versions. To avoid these, you should turn both options on."
www.renderviz.com
kippu is offline
Old October 13th, 2006   #7 (permalink)
Andrew1's Avatar
Hey Kippu,
Thanks, that did help, now I am getting nice sharp edge.
Andrew1 is offline
Old October 13th, 2006   #8 (permalink)
sMs
anyone knows a good reflectino tutorial?
any link?
sMs is offline
Problem with vray rendering nothingwrongtotryme VRay Render 4 August 4th, 2006 08:25 AM
VRay Kitchen : Glass reflection problem? purnomo_adi Work in Progress (WIP) 5 May 26th, 2006 12:42 PM
Vray Plane problem frazer VRay Render 2 May 5th, 2006 04:32 AM
vray light hotspot problem! please help ant_sutton VRay Render 4 August 24th, 2005 12:10 PM
vray: no gi with reflection virses VRay Render 6 October 8th, 2004 09:25 AM
