#2 (permalink) | |
try www.doschdesign.com and search for animated sky... That should do it
#4 (permalink) | |
Name: P D |
animated sky. How do i create a noise based animated sky and then bake the noise based sky onto a spherical map?
123 |
#5 (permalink) | |
I'm not going into detail unless I know you will be going that route. The suggestion of buying sky maps is perfectly fine, too. |
#6 (permalink) | |
Name: P D |
I would like to go down this route for definite and would appreciate any help you could give me, but if its to lengthy a process for you to describe here on the forum perhaps you could point me in the direction of a good tutorial for this topic. Thanks either way
123 |
First open C4D and try some stock skies out. Look in the plugins pulldown for the sky system. Find a sky that you like.
I think there is a tutorial, maybe its a video, on the 9.5 instalation discs. The baking is really easy, and would be the last step, so get the sky setup the way you like rendering with C4D. |
#8 (permalink) | |
Name: P D |
I think the idea is to save on render times which i have grasped when creating still shots but im still confused how this works when creating animations. To create the baked texture for the sky dome... do i select the preset sky to my liking then select a sphere primitve object then select bake object from the render settings. Once this is done do i locate and apply the baked texture back onto the sphere?
123 |
#9 (permalink) | |
Name: DANNY MARCION |
I haven't grasp the concept of baking yet and heard it does wonders for your render times..
i think a skyanimation is a simple yet effective way to create great effects to renderings, I'll love to learn how this is done as well...anyfeedback for us please post
I had a dream & now it's just another rendered image |
| Adding realistic clouds to sky or rendering | Timothy Saunders | 2D/3D Tutorials | 10 | August 18th, 2008 07:15 PM |
| Simple animated clouds...??? | akzit | 3ds Max | 4 | January 9th, 2006 11:20 AM |
| 3D clouds in MAX demonstration video, via MS FlightSim | Ernest Burden | General Discussions | 3 | July 12th, 2004 02:34 PM |
| Animated water | stinkyz | General Discussions | 7 | April 22nd, 2004 09:16 AM |
| Exterior Environment Mapping (clouds etc.) | tarn | Lightscape | 6 | March 5th, 2003 09:23 AM |
