Old October 19th, 2006   #11 (permalink)
Default Re: Time distance between keyframes
Ok so you do want to animate in Max BEFORE all the radiosity is done or AFTER? What I mean is u want to have all the keyframes intact BEFORE you actually do any 'solution processing'? For most people all the animation is done AFTER the .ls file is imported into max. I am sorry I am still not clear on what you want to do
_ _ ______________ _ _
Arnold Gallardo
Visual Content Creator
Technical Writer
and Techniques'
Arnold Gallardo is offline
Old October 19th, 2006   #12 (permalink)
o.k. heres the workflow.
I import dxf. file in Lightscape, define materials, lights, textures...initate. Radiostity calculations starts. When its "finished" models is illuminated.
Now I want to define camera keyframes, path, where to look, inside of Lightscape.
But since Im not very happy with camera options in Lightscape I was thinking if its possible maybe to import ls. file in Max, define camera keyframes, path inside of Max, then export animation path back to Lightscape and render animation in Lightscape.
Beeeee!
del82 is offline
Old October 19th, 2006   #13 (permalink)
Thanks for the clarification. However, sorry you can't do this. You cannot EXPORT out of Max an .ls file. Why? because the moment you introduce ANYTHING, any change in a .ls (solution file) it BECOMES an .lp (prepration) file. This is why I told you form the very beginning that you should treat Lightscape as a 'radiosity plugin' for Max/Viz.
Sorry but it is the nature of .ls to not have any changes done even if it is only animation. The key here is to have somebody be able to export From Max an .la (lightscape animation file) based on the keyframes in Max/Viz.
Unless Hmm you have the patience of exporting EVERY FRAME in the max animation out as a .VW file? This is similar to what originally done by somebody in Lightscape to show an animation of a door opening. Too bad I forgot his name now LOL For those oldies in LVS, this was the animation that opened a off screen door showing a surfboard on Lightscape's old website. back there is was just done with a lot of .ls files rendered as a single frame.
I take it that you don't like the way max/viz renders the .ls file? You're not alone I hope this answer your question.
Arnold Gallardo
Technical Writer
and Techniques'
Old October 19th, 2006   #14 (permalink)
Yes thats what I want.
Just to export .la file from Max back to Lightscape.
I though Chistians (Sismograph) script comes in the game here?!
Beeeee!
del82 is offline
Old October 19th, 2006   #15 (permalink)
http://www.cgtechniques.com/goodies/ls_la_exporter.php
Yes I am sorry I forgot about this maxscript. I have only used it in Max 5.1 tho since I render my animation in Lightwave 5.6 (yeah I know very old) but I like the way it renders my .ls files vs Max.
I'd do some tests and let you know Ok the maxscript works but not always. Sometimes there is a discrepancy in the imported .ls as far as 'scale' goes. Myabe somebody who has used this in Max7/8 can shed more light with this issue.
Arnold Gallardo
Technical Writer
and Techniques'
Old October 19th, 2006   #16 (permalink)
Maybe the author - Christian - we are waithing for your answer:-)
Beeeee!
del82 is offline
Old October 21st, 2006   #17 (permalink)
[url]I'd do some tests and let you know
Is it working?
Beeeee!
del82 is offline
Old October 22nd, 2006   #18 (permalink)
The export of .la file works and its input to max but as I said, when it it imported into LVS, the scale of the imported camera path spline is larger than the .lp file. I have to find out if this is a LVS reference Null issue or something else. But at least there is this path that you can use which is to animate in Max and render in LVS.
Arnold Gallardo
Technical Writer
and Techniques'
Old October 23rd, 2006   #19 (permalink)
Arnie, sorry for my bad english, but what do you mean by this?
Beeeee!
del82 is offline
Old October 23rd, 2006   #20 (permalink)
Switzerland Send a message via ICQ to rpict
there is also a handmade/script method for that purpose.
http://www.cgarchitect.com/vb/2747-a...ightscape.html
good luck
rpict is offline
Greetings all-quasi first time post...Please be gentle kwerch General Discussions 0 March 25th, 2006 01:06 PM
Survey - Time Wise the.3dsmax.blogger General Discussions 39 November 3rd, 2005 03:10 PM
Time expected for finals.... Mirage FAQ (Frequently Asked Questions) 4 February 7th, 2005 12:48 PM
About time Part II garethace General Discussions 2 August 13th, 2003 03:53 AM
How to improve on CG skills with limited time given? Josh General Discussions 2 July 12th, 2002 03:27 AM
