Old March 4th, 2008   #5 (permalink)
sedus69
France  Send a message via MSN to sedus69
Default Re: PSD Manager for MAX 2008?
Everything works just fine with my 2008 X64 version and PSD MANAGER 2.0
Be sure that you got a 3dsMax8Folder\CEBAS\PSDMANAGER with Psdmanager.chm (help file) psdmanage.dlv (Plugins)
and Check that it is lauch at Max2008 start
check your plugin.ini located at
Driveletter:\Documents and Settings\USERACCOUNT\Local Settings\Application Data\Autodesk\3dsmax\2008 - 64bit\enu
Everything works fine for 6 month.
sedus69 is offline   Reply With Quote
