Old March 6th, 2008   #4 (permalink)
daveb867
Default Re: sky portal intensity
ok so technically for physical correctness, if i have a building in its correct geographic location and modelled to the correct scale. if i then place a daylight system with mrsun and mrsky and mrphysical sky and sky portals at every window, if i then enable mr photographic exposure and choose the preset interior setting - your telling me that all i need to do is enable final gather and all the lighting will be physically correct???
i'm not sayin i don't believe you but half of my sky portals are way to intense on the scene even if i do everything as above
