Old March 10th, 2008   #2 (permalink)
Brian Bradley
Brian Bradley's Avatar
Default Re: Gamma correcting images
Originally Posted by SandmanNinja View Post
I've gone to my Preferences -> Gamma and LUT tab and a Gamma of 2.2 is applied.
Should I not be using it? I don’t recall turning this option on, so I assume that Max shipped with it turned on.
Thanking you...
Hey Joel,
Gamma settings are saved with the file (if enabled) so with
each file you open you should get the option to enable/disable
Gamma so a to match the scene file settings!
Regards
Bri
www.mentalboutmax.co.uk
The MBM Blog
Vray Learning Resource
www.vrayelite.com
Brian Bradley is offline   Reply With Quote
