Autodesk VIZ Autodesk VIZ
Old October 15th, 2006   #1 (permalink)
Brolloks's Avatar
Name: Isaac van den Berg
South Africa
Default Backburner & IP Address
HI
I normally don't have issues with backburner but the setup has changed and no I have an issue.
Viz2007 is running on a workstation with a network license. I have 2 other pc's running as render slaves also with Viz2007 installed but no serial or network license since they won't be used as workstations.
Backburner has been updated to 3.0.2 on all pc's
In the Backburner monitor the two slaves show up with an IP address of 255.255.255.255 which is not what the pc spits out when queried via ipconfig. The network is set up around 192.168.0.xxx
This does not seem to bother backburner as I can submit jobs and they will render. The problem comes in with Vray's distributed rendering as it cannot resolve the IP address....
Any pointers?
Dual Core x86 F:6, M:15, S:2 @1.8GHz
2GB RAM
Max 8 SP3
VRay 1.5 RC3
Brolloks is offline
Old October 15th, 2006   #2 (permalink)
Brolloks's Avatar
South Africa
Default Re: Backburner & IP Address
and a screenshot
2GB RAM
Max 8 SP3
VRay 1.5 RC3
Brolloks is offline
Old October 18th, 2006   #3 (permalink)
Originally Posted by Brolloks View Post
and a screenshot
All the backburner server's we have show up as 255.255.255.255 in the monitor, and they seem to work properly.
When you are setting up distributed rendering, are you adding servers by computer name or ip address?
squeakybadger is offline
backburner stiching error vikkramg 3ds Max 4 October 8th, 2006 10:54 AM
URGENT: BackBurner issues: random picking order?? nisus 3ds Max 7 April 25th, 2006 04:43 PM
MR - .pmap and .fgm files on Backburner MegaPixel 3ds Max 3 November 1st, 2005 11:09 PM
Backburner log in/out Rick Eloy 3ds Max 7 April 8th, 2005 08:21 AM
Backburner Server as service (serversvc) jucaro 3ds Max 8 December 21st, 2004 11:34 PM
