Old October 15th, 2006   #1 (permalink)
Default vray interior help
im pretty new to vray, infact this is my first vray attempt
im having trouble with the lighting of my scene. ive have one tarrget direct light which is acting as my sun with vray shadows. ive also to vray shadows which are sitting inside my windows frames. they seem to be very bright even though the multipler for each is set to 2. the doors in the right of the image also have vray lights in them. but i am not getting the same problems i am on the left.
were am i going wrong?
am i on the right track with vray?
thanks
foorked1 is offline
Old October 15th, 2006   #2 (permalink)
nicnic's Avatar
Default Re: vray interior help
i think you are on the right track, just turn down the multiplier on teh vray window lights, id gove the sun a slight warm colour as well, same with the vray lights, put a cool colour on them. You could also just turn on the environment and lose the vray lights in the left windows. Lookign good for a first attempt!
nicnic is offline
Old October 16th, 2006   #3 (permalink)
mahorela's Avatar
you haven't mentioned whether you have turned on global illumination or what settings you are using. Your rendering settings are just as important as your light settings. As mentioned, warmer colours for your sunlight and you need to change your exposure control to exponential for interiors (in the gbuffer dialogue box I think). That will make a big difference. Will give you a start. If I were you I would seek out some Vray beginner tutorials as I think it will be hard trying to learn good settings by trial and error.
mahorela is offline
Old October 16th, 2006   #4 (permalink)
ive done some more fiddling about. and now i only have two lights. a target direct light for the sun casting vray shadows and a sphere vray light inside of the lamp.
im a little frizzled about splotchy areas around my window and door frames, does this happen becasue i have geometry overlapping in thoughts areas?
ive done a few tutorials from evermotion and vismasters. they are helpful, but i cant find answers some of my problems.
suggestions? i scene seen to dark and lifeless?
foorked1 is offline
Old October 18th, 2006   #5 (permalink)
mahorela's Avatar
those splotchy areas can also happen if your irradiance map or light cache (secondary bounce) settings are too low. They are common for me when I am test rendering on low settings but dissapear when the settings go up for the final. Aside from your two lights there is also another light at work in Vray GI scenes providing you have turned on the override max environment button in the environment dialogue of your vray renderer. It works like a skylight and by default is set to 1.0, if you want more light just up the skylight. Alternatively, most people mess around with the exponential exposure control settings like.....dark=2 light=1.5. This will also brighten your scene.
mahorela is offline
Old October 18th, 2006   #6 (permalink)
yeah thanks, your a great help! that last one was rendered without exponential. which has improved considerbly. unfortunatly i lost that test scene, becasue 3dsmax crashed.
just curious about what exposure control would best suit exteriors?
foorked1 is offline
Ten vray questions steve VRay Render 10 September 13th, 2008 10:20 PM
VRay training Brian Smith VRay Render 0 June 6th, 2006 08:46 AM
Vray, Maxwell...................?? bully712 VRay Render 16 April 5th, 2005 08:36 AM
Vray and Brizal Rio plug in Chris Potts Other 3rd Party Renderers 7 September 16th, 2004 02:01 AM
VRay against Vray and ... Sergio VRay Render 15 May 30th, 2003 09:09 AM
