Old October 16th, 2006   #1 (permalink)
Default vray bitmap filter + memory error
Hi all
i am rendering a 3d view of a complete society which has a number of villas , a shopping mall , a multisoreyed housing and other things . its a big scene . i am using vray 1.47.03 and max 8 for rendering. but when i am trying to render it its giving me the following error even if i render it at a low size of say 800 x 600.
i have also increased the virtual memory but of no help
My system specs are
AMD x2 4200 +
2 gb ram 320 gb hdd
256mb PCI express card.
How can i solve this prolem
3dsmaxed is offline
Old October 16th, 2006   #2 (permalink)
Default Re: vray bitmap filter + memory error
there r so many reasons.. depends on ur scene setup
1) if u r using very high res. texture.. reduce there file size in photoshop and then use.. using very hires texture makes sftwre runin out of memory
2) if u r using caustics.. try rendering wthout caustics
3) if using light cache then check sample size..use screen n not world.. if world then try using sample s ize >1
4)if ir map.. try rendering scene wth low preset.
best of luck
prateek
prateekvishwa is offline
Old October 16th, 2006   #3 (permalink)
kippu's Avatar
well as the error msg suggests...you are running outta memory
www.renderviz.com
kippu is offline
Old October 16th, 2006   #4 (permalink)
lambros's Avatar
Name: Lambros Potamianos
Greece
I experienced same problems before, usually I just had to take hires images to photoshop and scale them down, as suggested. Having a 4K texture for wooden floor would just cause trouble if a 2K render with a partial view of the floor is what you are after. Jpgs may be small sized (in Kb terms) but they are decompressed once loaded and flood the system.
lambros is offline
Old October 16th, 2006   #5 (permalink)
manta's Avatar
Try using vray proxy's...
Try using windows X64...
Try using QMC instead of light cache...
any or all should do the trick...
DESIGN FORWARD
http://www.mantastudios.com
manta is offline
Old October 16th, 2006   #6 (permalink)
How to check which bitmap is causing problem
because everytime each gives error for a different object with a different bitmap
how to handle such a scene which has same copy of a villa x 300 times?
I always used instance but instances also give this kind of memory error.
Also copying things slow down the viewport even if i am using a 256 mb PCI express in my system
Any suggestions
3dsmaxed is offline
Old October 16th, 2006   #7 (permalink)
I am using QMC already
using Vray proxy now after so much wrk and texturing is looking a bit difficult to me
Is there any way by which , when converting the villa into a proxy object, it should automatically creat a multisubobject material on its own taking into account all the different materials that are applied to it.
Will windows x 64 actually solve the problem?
I know you mentioned this already on this forum but does it actually works?
thanks
3dsmaxed is offline
Old October 16th, 2006   #8 (permalink)
manta's Avatar
Well check to see how much memory you are using while rendering, X64 will allow you to use 3.6GB before crashing...
DESIGN FORWARD
manta is offline
Old October 16th, 2006   #9 (permalink)
will enabling the 3gb switch help?
3dsmaxed is offline
Old October 16th, 2006   #10 (permalink)
manta's Avatar
yes...it will probably let you go as high as 2.86GB's with Max...
DESIGN FORWARD
manta is offline
Memory issues - Bitmap Filter Error lochlan1 Hardware and Technical Discusions 8 September 28th, 2006 11:59 AM
Bitmap Filter Error? Claudio Branch 3ds Max 3 March 20th, 2006 09:24 PM
Vray DR error gfa2 VRay Render 6 August 25th, 2005 05:54 AM
Memory error after 30 frames of animation in MR Gwilliam 3ds Max 2 July 1st, 2004 11:32 AM
about memory, is it really true that...? salf Hardware and Technical Discusions 2 March 30th, 2004 12:59 PM
