Old October 16th, 2006   #1 (permalink)
Netherlands
Default background bitmap
Hi all
I've got this scene with a sky background bitmap..when I render ir in a exterior view I can see the sky..when I get into the house and render a interior view I can't see it...
The window is glass and there is a Vray Light in each window...the vray light is exactly the same size of the window do fake the sun light entry...
The background image is set in the Rendering Environment (key 8 for shortcut).
does anyone knoes why this happens?
Thanks a lot
File Type: jpg interiores_teste4_com_GI e sem dfault lights.jpg (189.1 KB, 40 views)
drvox is offline
Old October 16th, 2006   #2 (permalink)
lambros's Avatar
Name: Lambros Potamianos
Greece
Default Re: background bitmap
well, two things:
- vray lights are blocking the view, you have to check "invisible".
- the glass vray material should have "Affect shadows" and "affect alpha" enabled, to be really transparent and allow shadows to enter the interior
lambros is offline
Old October 16th, 2006   #3 (permalink)
Netherlands
Thanks a lot..it wasn't set as invisible!
Another thing that I can't find is a way to render images with more pixels (I guess this is what I want).
If i print this picture it will have very little white points...the same happens if you zoom it... It was rendered with high quality in the Irradiance Map (Primary), but I sitll can't get rid of those points... I've rendered it with a resolution of 800X600...
This is nice for me to get an idea of the final result...but I wanted to get something better in the final render...Any help?
King Regards
drvox is offline
Old October 16th, 2006   #4 (permalink)
lambros's Avatar
Greece
i can't see any white points. Can you be more specific, or show us a picture?
lambros is offline
Old October 16th, 2006   #5 (permalink)
Netherlands
I only have some test scenes..here is another.. But I wonder if this image couldn't have more pixels??
Thanks!
File Type: jpg interiores_teste6_com_GI e sem dfault lights.jpg (202.0 KB, 38 views)
drvox is offline
Old October 16th, 2006   #6 (permalink)
lambros's Avatar
Greece
I can't really seem to find any problems with your renders. If your render at greater sizes, what is the problem? will there be artifacts? if yes, please post a larger render pic.
lambros is offline
Adding a Background baker1444 VRay Render 5 October 23rd, 2006 11:10 PM
How to turn off anti aliasing on the environment background image Jefferson Grigsby VRay Render 1 September 26th, 2006 07:31 PM
problem rendering with background bitmap drvox VRay Render 7 August 16th, 2006 07:58 AM
How to do a specular bitmap? archkre 3ds Max 9 January 6th, 2005 08:20 AM
background ...help! lucho General Discussions 2 April 2nd, 2004 01:55 PM
