Old October 16th, 2006   #1 (permalink)
Venezuela
Default issue extruding a roof
Ok, heres the thing, I have to make a 3d model, of a roof, its like a long walkway covered with a roof.
If you see the floorplans, the shape of the long walkway its almost like a "Guitar" shape, so what IM doing is using the roof section, and extruding it along the curved path.
However im having issues with this, at the end of the "path" the roof is distorted, it changes its angle, or if you see it in teh top view, you noticed it didnt quite follow the curved path.
ANy idea how to solve this?
salf is offline
Old October 16th, 2006   #2 (permalink)
Default Re: issue extruding a roof
if the extrusion isn't working, sometimes i just create a wall object along the path and use the roof profile as a sweep in one of the components
ITryMyBest is offline
Old October 16th, 2006   #3 (permalink)
Venezuela
uh?........this is an english board.......
*scratches head*
salf is offline
Old October 16th, 2006   #4 (permalink)
Sweep is a new acad 2007 command. It works pretty much as the follow me tool in sketchup.
mcorrea is offline
Old October 17th, 2006   #5 (permalink)
Venezuela
ohhhhhhhhhhhhhhh......ok.....got it now.....altho I cant use it, since I have 2006.
Now, another question, in this project I have rounded columns, whenever I import the file to MAX, the colums are all messed up, not rounded, in another file I had the same problem, but I fixed it by moving all the 3d model in Autocad to the point 0,0,0, since its was too far away form it, and when importing to MAX it fixed the colums and other model issues, but it doenst works with this file, any idea?
salf is offline
Old October 18th, 2006   #6 (permalink)
Antisthenes's Avatar
Name: Jonas Callewaert
Belgium
Rhin...
Antisthenes is offline
How do you model a roof? Gnarly Cranium 3ds Max 30 June 5th, 2008 11:43 AM
metal roof raterry 3ds Max 3 December 9th, 2005 12:50 PM
Mental Ray Roof spyder2411 Other 3rd Party Renderers 3 July 12th, 2005 01:03 PM
Changing default Roof Slab Angle? Alex Ryan Rubio AutoCAD/AutoCAD Architecture 2 June 25th, 2004 03:07 AM
Anyone know a good technique for roof tiles? Erik Lund 3ds Max 7 November 8th, 2002 08:48 AM
