Old October 17th, 2006   #1 (permalink)
pg1
Ireland
Default light cache problem,maybe?
I just started doing an interior animation using light cache and pre cal. irmap.
image sampler adaptive subdivision
med animation setting with 50hsph and 20 interp. samples
light cache
subdivs 500
sample size 10mm
scale world
filter nearest
I also have set the walls to generate gi. 1.2
I am getting an error at the corners of the walls as you can see in the attached image.
Is this a light leak? or a problem with my light cache settings
whatever it is how do I get rid of it.
pg1 is offline
Old October 17th, 2006   #2 (permalink)
Name: Kristoffer Hägelstam
Sweden
Default Re: light cache problem,maybe?
I would try to increase the light cache subdivs to 1000 or higher, this may get rid of the light leak in the corner.
You also might want to try to use high settings on the irradiance map, you wrote that you used a pre. calc irradiance map so you will still get fairly fast results, just add the new high irradiance map to your old calc.
One way or another, to get rid of the light leak you need to pump up your settings.
keito is offline
Old October 17th, 2006   #3 (permalink)
BrianKitts's Avatar
i don't see any attached image, but most likely 500 isn't anywhere close to the number of subdivs your need in your lightcache settings. the precalc will divide those subdivisions throughout the entire length of the animation, thus lightcache anim subdiv's can easy be around 2000, it all depends on how the size of your scene and how far you travel in your animation.
Brian Kitts
ANSHEN + ALLEN
BrianKitts is offline
Old October 17th, 2006   #4 (permalink)
kippu's Avatar
show me the light positions with a wireframe
www.renderviz.com
kippu is offline
Old October 18th, 2006   #5 (permalink)
pg1
Ireland
Hey guys was up the walls yesterday so haven't gotten back to the animation yet.
The reason you cant see an attached image is because I accidentally double posted and 'quizzy' (moderator) had to delete them and repost, which lost the attachment.
I think, because I'm sure it was there yesterday.
Unless all these late nights in front of a computer have finally made me delusional.
Anyway I have uploaded it again with pics or when the direct light is.
Will definately increase the light subdivs hopefully that will sort it.
pg1 is offline
light cache becomes darker darth VRay Render 3 April 24th, 2006 03:48 AM
why is it different?(images included) qmc and light cache d7man2000 VRay Render 8 February 20th, 2006 01:03 PM
Light Cache for several views akzit VRay Render 4 January 12th, 2006 05:03 AM
light cache problems carlangas VRay Render 7 December 6th, 2005 10:47 AM
Light cache question. Tommy L VRay Render 2 July 13th, 2005 06:46 AM
