Old March 17th, 2008   #9 (permalink)
Horhe
Horhe's Avatar
Default Re: 2008 AVC Competition has been Launched!
Originally Posted by Justin Hunt View Post
sorry still lost, what shapes link?
jhv
Rules 1. You must use all of the shapes and primitives provided in your scene
2. You can not modify the geometry of the provided shapes in any way, EXCEPT to uniformly scale them up or down in size or to add small fillets/chamfers to catch the light on the edges. If you do scale them the original proportions must be maintained.
3. You can re-use the shapes in the scene as many times as you like and they do not all have to be the same scale.
4. You can apply textures to the shapes or solid color.
5. You can not introduce any other geometry to the scene other than what is provided, with the exception of a flat ground plane.
6. The background plate can be a solid color, a gradient or a bitmap of your choice.
7. Please be sure to read the main competition RULES
DOWNLOAD YOUR SHAPES HERE (113KB)
This ZIP file contains the following file formats: 3dsmax 6, 3ds, DWG, D
Horhe is offline   Reply With Quote
