Old October 18th, 2006   #1 (permalink)
Uruguay
Thumbs up Vray frame buffer vs. MAX frame buffer
hello, could someone tell what´s the diference between max frame buffer and vrays?, Is the vray`s better in img quality or what???
thanks
Al.
alvstel is offline
Old October 18th, 2006   #2 (permalink)
Denmark
Default Re: Vray frame buffer vs. MAX frame buffer
The image quality should be the same. The Vray frame buffer is just like max's own but on steroids. It will allow you to view your image with custom gamma, it will show you which colors are "burned out" ie too bright. It will also show you selectively all the g-buffer channels you might have rendered out (like z-depth, raw lighting, GI etc) and let you save those individually. And much more.
The only problem is net-rendering a large image to the vray buffer - will lead to a crash. This is probably fixed in the latest release.
3dfreelancer
3dfreelancer is offline
which vray for max 7 philip kelly VRay Render 7 March 9th, 2005 04:32 AM
loading vray in max 6 Munz 3ds Max 2 May 21st, 2004 03:04 PM
Max and Vray - please help stylez 3ds Max 16 May 9th, 2004 12:10 PM
VRAY to MAX materials quizzy VRay Render 3 January 27th, 2004 05:00 AM
