Old October 18th, 2006   #1 (permalink)
maxkid's Avatar
Canada  Send a message via Skype™ to maxkid
Question rendering animation seqence on the networ with vray
Hi guys,
Here's my simple query :
can you use vray 1.47.03 advanced version to render animation ( having your irrdiance map saved on the network ) to render whole sequence ,well i tried doing so and vray only renders frame 1 of the whole seq , the rest frames were rendered only on my machine ,is there any method by which you could use vray for rendering an entire seq say 100 frames on the network ,
if it renders one frame on the network it should other 99 too ,not something I understand...just like how backburner does.
please help me out here....
cheers,
dari
maxkid is offline
Old October 18th, 2006   #2 (permalink)
manta's Avatar
Default Re: rendering animation seqence on the networ with vray
are you using backburner...
DESIGN FORWARD
http://www.mantastudios.com
manta is offline
Old October 18th, 2006   #3 (permalink)
maxkid's Avatar
hi,
Yes i am using backburner and ir map is saved on the network ,but when i put on rendering using backburner it shows different result on my computer and much darker image ( without Gi ) on other computers ,what possibly be the reason be since my irradiance map is saved on the network....
cheers,
darshan
maxkid is offline
Old October 18th, 2006   #4 (permalink)
manta's Avatar
Make sure you are using absolute UNC paths for everything...
just use
\\myserver\resources\proxies\proxy
instead of
V: (mapped drive)\resources\proxies\proxy
DESIGN FORWARD
manta is offline
Vray Distributed Rendering Queue? Piolit VRay Render 13 April 17th, 2007 08:34 AM
Vray distributed net rendering? Craig Ramsay VRay Render 9 May 4th, 2006 10:23 AM
what is the best animation configuration for VRay? Ghiath VRay Render 5 February 2nd, 2006 01:06 PM
Interior Animation - Vray ManoloRC Finished Work 5 November 28th, 2005 02:12 AM
animation with vray arnold@asylumstudio.co.za 3ds Max 2 October 22nd, 2004 04:43 AM
