Name: Greg Hess |
Wayne,
http://xona.com/2004/07/22.html Just tested it out, works fine! If you need to set affinity, you'll need the resource toolkit to do so. |
Here's another one that's probably easy. How do I make mental ray's Raysat for Max run as below normal priority? It's a service and it runs under System account so I can't do it in Task Manager. I'd like to run it on some other office PCs without making them slow.
Name: Greg Hess |
http://www.beyondlogic.org/solutions...rocessutil.htm
Trying to find out how to set it when installing a service. |
Name: Greg Hess |
I wouldn't say hard, just annoying. Usually when things start pointing to downloading microsoft resource kits, I try to find other solutions. It used to be that you could download just the file you needed, and not have to deal with all this verification and authorization crap to fix your problems.
I'll see if I can find something on monday...there used to be just some command line you executed... |
| 3DS MAX Default scanline | chunwai | Finished Work | 12 | November 8th, 2005 04:05 PM |
| save out, just the shadows as a channel, using the default scanline renderer | melodycarter | 3ds Max | 3 | September 27th, 2005 08:46 PM |
| 3D Layer Name Standards | joseph alexander | General Discussions | 4 | August 19th, 2005 10:18 AM |
| changing the default lights characteristics | salf | 3ds Max | 2 | May 7th, 2005 10:30 AM |
| UI and Default Switcher: can I customize it? | Rick Eloy | 3ds Max | 4 | September 23rd, 2004 11:03 AM |
