Old October 19th, 2006   #1 (permalink)
Talking Hi-res satellite photo in Max
Before the days of direct 3D and Xp64, I used the Maxtreme driver for just about everything in Max. Now that we have upgraded to xp64, the Maxtreme driver is no longer supported and does not work.
The best feature was its ability to display hi-res textures in the viewport. With Direct 3D, I am limited to 512x512, where Maxtreme allowed up 4096x4096. Thes was great for tracing over large satellite images.
does anyone else have a soluation for this, or know if there will be any updated maxtreme drivers for xp64?
thanks in Advance
Jefferson Grigsby
Jefferson Grigsby is offline
Old October 19th, 2006   #2 (permalink)
martin walker's Avatar
United Kingdom  Send a message via MSN to martin walker
Default Re: Hi-res satellite photo in Max
you could trace over it in photoshop and then export the path, and bring it into Max ?
martin walker is offline
Old October 19th, 2006   #3 (permalink)
hmm, will give it a try.
Still interesrted in finding a new driver for max. Maybe autodesk will find a solution here.
thanks
Jefferson Grigsby
Old October 19th, 2006   #4 (permalink)
President/Founder
Jeff Mottle's Avatar
It's unfourtunate that the company I know that has a solution for this has no ethics, or I would reccomend them to you. They owed us a great deal of money and they broke a legally binding contract.
Have you tried posting on the 3ds max forums? There is likely some GIS guys on there.
Found this link on Google, but not sure if it's what you are trying to do. Also requires that you have ArcGIS.
http://www.gsd.harvard.edu/gis/manua...23ds/index.htm
Jeff Mottle
CGarchitect.com
Jeff Mottle is offline
Old October 19th, 2006   #5 (permalink)
different problem, but something else we were looking into. Thanks for the link.
Old October 20th, 2006   #6 (permalink)
New Zealand
thanks in Advance
Jefferson Grigsby
We use to import it into autocad and that worked well then just saved the lines out as a .3ds file and imported to max
CookiE is offline
Revit To Max, Why Such A Nightmare?? Jefferson Grigsby AutoCAD/AutoCAD Architecture 2 August 5th, 2006 12:28 PM
3ds max 8 won't launch on Opteron/WinXP64 render nodes ShaunDon Hardware and Technical Discusions 8 July 8th, 2006 09:16 PM
3ds MAX and W2K SP 4/Hot Fix Issues Jeff Mottle 3ds Max 16 October 10th, 2003 12:07 PM
