Thread: Max 64bit
Old March 22nd, 2008   #8 (permalink)
leonmagnavox
Default Re: Max 64bit
guys i have 8 gigs too with (xp64/max64/vray64)
the problem i have is; i try to test render evermotion interior scene and the Ram wont go more than 4 gigs all the time.
I switch boot.ini with \8GB ; it said available in task manager but max64 just wont take it.
It cant be because of the process doesnt require ammount of 8 gig of ram; because I tried to render in 20.000 x 10.000 resolution and still just take less than 4GB
Is it possible that RAM speed or Graphic Card affecting this?
all I can see is that 8 processor always runs in 100% mode (task manager)
how much affecting the speed of ram (fully buffered/ecc) from 533/667/800mhz for rendering purposes (max+vray)
my processor is 2x quad xeon 3ghz 1333fsb
and the test renders mostly done around 30 minutes in 1200x600 resolution
weirdly, max32 in the same system is 5 minutes faster
thanks alot
leonmagnavox is offline   Reply With Quote
