Old November 2nd, 2006   #31 (permalink)
Default Re: Memory usage
Todays results of processing radiosity in (same file):
Lightscape: 9:00 min
eScape : 9:30 min
LSnet : 9:30 min
Lightscape in the lead!
Interesting phenomenon
Also today the "black parts" that render black due the diferent graphic chipset, dissapered.
Im not drunk or high.
Beeeee!
del82 is offline
Old November 2nd, 2006   #32 (permalink)
what about using LSrad? You should try a PURE command line routine. Altho LSnet has no GUI eScape does as well as LScape.
_ _ ______________ _ _
Arnold Gallardo
Visual Content Creator
Technical Writer
and Techniques'
Arnold Gallardo is offline
Old November 2nd, 2006   #33 (permalink)
Isnt LSrad same thing that you have in eScape when you start processing?
This is crazy!
Beeeee!
del82 is offline
Old November 2nd, 2006   #34 (permalink)
yeah but you are STILL using a GUI (eScape) to render. In my almost ten years of using LVS, I have never seen an .lp file process as fast as in LSRAD much less compare it with LSCAPE's. Its at least 30-50% faster if not more.
Arnold Gallardo
Technical Writer
and Techniques'
Old November 3rd, 2006   #35 (permalink)
Yeah but you only see numbers pumping, noting like when you see the whole scene processing in Lightscape.
Beeeee!
del82 is offline
Old November 3rd, 2006   #36 (permalink)
Is there an rational explenation for this
I mean one day is o.k. one they apear again
Beeeee!
del82 is offline
Old November 3rd, 2006   #37 (permalink)
The updating of the GUI as well as the openGl and whatever else is what makes it SO SLOW. Why dont you try the command line LSRAD? Dont you know that LSCAPE is only a GUI? everything else is being done by LSRAD?
Using LSRAY is also faster than Lscape. Yes, LSRAY is what is being used to raytrace and LSRENDER is used to generate images from the solution files.
Arnold Gallardo
Technical Writer
and Techniques'
Old November 3rd, 2006   #38 (permalink)
Almost there
A bullet in my head!
Beeeee!
del82 is offline
Old November 5th, 2006   #39 (permalink)
o.k. Im runing out of patients
I have th same graphic cards on two of my nodes.
When they are the only ones, ON, that is rendering, get the same god damn thing again, black renderes...sometimes the whole picture is rendered out dark.
So this couldnt be due the graphic cards, or...?!
Is it possible to get with someone proffesional in contact to solve this somehow, or anybody with experince, and I know there are a lot of people here that still use Lightscape or were using it...
Please help:-(
Beeeee!
del82 is offline
Old June 26th, 2007   #40 (permalink)
Would I gain speed in radiosity processing, if I have 3Gb RAM with my E4300 thats clocked on 2,4 Ghz (present ram situation is 2 GB)?
Thank you!
Beeeee!
del82 is offline
CS2 - max memory limit on G5? (X-posted) 4DM Photoshop 4 April 29th, 2005 05:17 PM
About Physical and Virtual memory. salf 3ds Max 3 June 16th, 2004 06:31 AM
Memory Upgrade digi_archi Hardware and Technical Discusions 0 May 1st, 2004 10:25 PM
about memory, is it really true that...? salf Hardware and Technical Discusions 2 March 30th, 2004 12:59 PM
RPCs and Memory Usage Jeff Mottle 3ds Max 16 May 28th, 2002 03:22 AM
