Old June 11th, 2002   #3 (permalink)
quizzy
quizzy's Avatar
well, if you cant find an option to give the doors different material id's in ADT3.3 the only thing to do is to collapse the ADT door to an editable mesh and edit the material id's by hand. But this is a very "painfull" way, you better use the standard doors and windows from VIZ. Those ones have material id's allready....
Have you tried to export those doors as an 3ds file and then import them into VIZ?? That might be a trick too, I don't know ADT3.3 but anyways hope this helps.....
Michiel Quist
http://www.3idee.nl
quizzy is offline   Reply With Quote
