Hi Dre
Sounds like the colours in your ADT3.3 window object definition are all set to colour 8. From ADT, using the model display representation of the window, try setting the colours of the various window components objects to colours which map onto the material slots defined in your multi-sub object Viz material. Sequence as follows.
From a model display rep, select window, right click, edit window style, select Display props tab, Layer/Colour/Linetype dialogue, assign appropriate colours to the frame, sash and glass components, save the definition, update the file linking.
If the window is specific, you would define it as an override attached to the Window Style.
Hope this helps
Kerry Thompson
