Old October 27th, 2006   #1 (permalink)
Default Vray light reflection problem?
I have an interior scene (apt) with an environment beyond the windows. There are vray lights behind each window. When I render looking at/through the window, I see the environment behind, no problem here. However, across from the window is a glass wall that when it reflects (ie: you see the reflection of the window in the glass wall) it does not show the environment behind the window, instead it reflects a large white square, that being the vray light. The light is invisible, it only shows up in reflection. Is there anyway to solve this problem of the vray light reflecting in a material. I need to see the environment in the glass wall reflection, not the hotspot of the light.
Any help would be appreciated.
Thanks,
Matt
Piolit is offline
Old October 27th, 2006   #2 (permalink)
olbo's Avatar
Germany
Default Re: Vray light reflection problem?
Heya Piolit,
you could update to V-Ray 1.5RC3 and use the new option (Affect specular)
in the V-Ray lights and turn it off. If you can't update right now, ... well I
guess the easiest way is to exclude the glass wall from the light. Don't know
another option right now. Hope this helps a bit. ;o)
take care
Oleg
"Aux larmes Citoyens, Aux armes Citoyens" - Philippe Starck
olbo is offline
Old October 27th, 2006   #3 (permalink)
That seems to work, thanks.
Piolit is offline
Problem with vray and backburner pradipta VRay Render 2 August 29th, 2006 12:26 AM
VRay Transucent problem Carrotious VRay Render 4 August 10th, 2006 08:43 PM
Vray Pendant Light kwerch VRay Render 3 May 9th, 2006 07:28 PM
vray problem carlangas VRay Render 5 July 25th, 2005 01:08 PM
Problem with Vray Free nhj84 VRay Render 3 July 18th, 2005 01:55 PM
