Re: Viz4 render problem
it was acutally a modeling problem in cad when you move certain objects in 3d mode in cad... it tends to not align.. because of the different axis. as it turned out, the wall in which the corrugated panel sits on somehow was overlapping it and causing the render to become flat bec. the corrugated is being overlapped with a flat wall.
thanks for the reply.
