Old October 31st, 2006   #1 (permalink)
Default clubhouse garden sit out-Vray & HDR
Hi!
Attached is an exterior image of a clubhouse garden sit out done with Vray & HDR. Need your comments for same to improve my work.
Thanx in advance.
TV
tejalvirkar is offline
Old October 31st, 2006   #2 (permalink)
Default Re: clubhouse garden sit out-Vray & HDR
First off I like the composition, looks good & some good lighting. I feel the texturing doesn't work though, the brick walls look a bit mapped & clean. Maybe get some dirt maps on there or do some post painting in photoshop. I also feel the trees in the background are very flat and look fake. Also (being a bit fussy here) the dark wooden roof truss distracts my eye & looks cgish.
I hope this is of help m8.
sdds is offline
Old October 31st, 2006   #3 (permalink)
Malaysia
A little bit more contras would help...could also improove on grass since youre using vray...higer settings in all mat subdivision would be great.
visual3d is offline
Old November 1st, 2006   #4 (permalink)
Thanx Reza & simmon!
I will surely try to get the suggestions done.
Those r worthy and helpful for a person like me who is still learning& exploring Vray &HDR.
TV
Old November 2nd, 2006   #5 (permalink)
mahorela's Avatar
Upping the bump on the bricks would help alot and in my opinion the image needs to be sharper (AA) (personal preference). I also think that the grass looks a little odd and indistinct (is it displacement?).
It can be hard sometimes working with HDRI to get the ideal lighting for your scene. By this I mean that although your lighting might suit the HDRI your using.....Does it provide lighting that best shows off your scene. In this case the lighting seems dull and cold whereas I would personally be looking for something warm and inviting here.
mahorela is offline
Old November 6th, 2006   #6 (permalink)
Hi!
Please have a look at this and give feedback. Changes are done as per ur prior suggestions.
THanks!
TV
Old November 6th, 2006   #7 (permalink)
mahorela's Avatar
huge improvement on the original.....very nice work
mahorela is offline
Old November 6th, 2006   #8 (permalink)
Hi Bob!
THanx a lot.It was possible cause of suggestions that i received from u all.
TV
Old November 6th, 2006   #9 (permalink)
edub's Avatar
what kind of slanted bricks are those?? never seen something like that
I guess they could exist, but you would have to make it look a bit more believable.
First of all, you mapping needs to be adjusted so that there is not a grout line at the bottom of the "arched" part (underside of flat part).
Secondly, you should consider a "soldier course" (vertical) of bricks for this same part, as it will imply greater structural integrity.
Of course, I have no idea if it's your intent to challenge conventional building methods.
Nice job otherwise!
edub is offline
Old November 6th, 2006   #10 (permalink)
Hey erik!
Thanx for ur valuable suggesstions. As far as the slanting brick and mapping goes i agree with u. But the part of vertical tiling didn't get. Can u explain? Actually i am learning to work with vray & HDR so...mistakes.
Would be glad if u give the tips always.
TV
Vray Hdr Evening tejalvirkar Work in Progress (WIP) 1 September 18th, 2006 06:21 AM
Vray and HDR output AJLynn VRay Render 4 September 14th, 2006 09:01 AM
VRay training Brian Smith VRay Render 0 June 6th, 2006 08:46 AM
Vray and Brizal Rio plug in Chris Potts Other 3rd Party Renderers 7 September 16th, 2004 02:01 AM
about Vray versions and VIZ 4.2 salf VRay Render 8 March 2nd, 2004 03:47 AM
