Old October 31st, 2006   #1 (permalink)
Ireland
Default Vray rc3 & max9 network rendering prob
Hi
I've got the upgrade to max 9 and downloaded VRAY RC3 too. Everything installed fine and I've setup network rendering with a few dual core machines.
Network rendering worked 1st time but with one annoying problem. For some reason on all my dual core render clients vray will only use one core. On my local machine its rendering 2 buckets (P4 HT enabled) but for all my dual core clients its only rendering 1 bucket and in task manager on the clients only one core is being used.
Has anyone come accross this? and if so have you a solution?
With max8 and the previous version of vray network rendering used to use the 2 cores fine (when it decided to work that is!)
Appreciate any help anyone can provide
phil
PS- I'd post this in the chaos forum only I'm still waiting for access to post in their forums!
philip kelly is offline
Old October 31st, 2006   #2 (permalink)
Default Re: Vray rc3 & max9 network rendering prob
If you get the answer from the Vray forum, please let us know the answer, as we're about to upgrade too. Are you using 64-bit anywhere? What OS?
DavidR is offline
Old October 31st, 2006   #3 (permalink)
Ireland
32 bit version. A
chaos group answer would be nice, but no access.................
Old October 31st, 2006   #4 (permalink)
Northern Ireland
Phillip try this it might fix your problem...........see below
For whatever reason, 3dsmax 9 seems to assume always 1 rendering thread when started in slave mode; we will work around this issue, but for now, you can force V-Ray to use a specified number of threads across all render slaves by opening the maxscript listener (f11) and typing:
renderers.current.system_numThreads=4
This will cause all render slaves to always use 4 rendering threads.
Best regards,
Vlado
tdarcy is offline
Old October 31st, 2006   #5 (permalink)
Ireland
Great .....your a shtarr.
That seems have worked , now how do I get that to start everytime i start up max.........?
But thanks you sacved me a lot of time .....
phil
max network rendering using vray qwarto VRay Render 6 May 2nd, 2008 10:37 PM
Setting up network rendering? IHAB Hardware and Technical Discusions 11 May 8th, 2006 04:42 AM
VRAY GI missing on Network render phiggins@degw.com VRay Render 3 April 21st, 2006 08:50 AM
RenderPal 2004 Server V1.60 - Next Generation Network Rendering brainspoon Industry News 0 September 14th, 2005 01:28 PM
network rendering problems??? miguelafi Hardware and Technical Discusions 5 April 2nd, 2003 05:24 AM
