Old August 27th, 2002   #1 (permalink)
plastic
plastic's Avatar
Austria
better post a picture.
be sure that there is no gap between the building parts. (zero distance)
you can try using different subdivision values. process radiosity and turn on 'edged faces' for the perspective viewport, then you usually see the problem.
you can also attach walls and floor to one mesh and weld the vertices.
Marc Lorenz
http://plugins.angstraum.at
My 3d gallery at Flickr
plastic is offline   Reply With Quote
