Old September 5th, 2002   #2 (permalink)
abicalho
abicalho's Avatar
There are some things you need to think of when excluding objects from Radiosity:
- Is there another light that is illuminating this object?
- Which rendering method are you using? Render Direct or Re-Use? When using Re-use, no lights are rendered, and only the radiosity light is used, so any object that's excluded will render black.
Hope this helps explain it.
Alexander | discreet Quality Engineer
Alex Bicalho
abicalho is offline   Reply With Quote
