Old April 13th, 2008   #1 (permalink)
Quirky
Default Rendering a perforated steel facade...
Hi,
I'm going to be drawing up a building with a perforated steel facade, as well as consisting of a number of steel mesh/ grated floors and walkways. I do all my drawing in Autocad and then import the drawing into Vis to render. Is there a tool to set a transparency to a material for the perforations, similar to a bump, or will I have to model each hole?! I tried modelling the steel mesh floor and the file became so big it was unmanageable!
Quirky is offline   Reply With Quote
