3ds Max Autodesk 3ds Max
Old November 8th, 2006   #1 (permalink)
United_States  Send a message via Yahoo to jtroupe
Default Trying to create a composite material....
I am trying ot avoid the tiling that you get with grass on a big area by making a composite material of 2 different grass materials. So far I haven't had any success. Either one or the other shows up, not both. I also wanted to include a third image to get the look like the grass had just been mowed and you get the lines back and forth. (See attached image).
I am using scanline render to do my images.
Any suggestions would be helpful.
Thanks.
jtroupe is offline
Old November 8th, 2006   #2 (permalink)
Default Re: Trying to create a composite material....
Looks fine to me it looks like it was 'mowed'
_ _ ______________ _ _
Arnold Gallardo
Visual Content Creator
Technical Writer
and Techniques'
Arnold Gallardo is offline
Old November 8th, 2006   #3 (permalink)
That image is not mine, I was just showing it to illustrate what look I am going for.
jtroupe is offline
Old November 8th, 2006   #4 (permalink)
Jordan
you have to use a Mask (black & white) map, put your first material on white areas & the 2nd on black areas & they will both show up
The_architect06 is offline
Old November 8th, 2006   #5 (permalink)
dinhtuan's Avatar
Viet Nam Send a message via ICQ to dinhtuan Send a message via Yahoo to dinhtuan Send a message via Skype™ to dinhtuan
You can use Mix material with grass maps at color slots and a mask (noise map) at Mix amount slot to mix.
http://www.vnimation.com/
dinhtuan is offline
want some help to create Grey Alluminium material..... yogeshwagh VRay Render 7 August 3rd, 2006 07:25 PM
shell material v-cube 3ds Max 1 May 19th, 2006 09:31 PM
How To Create Flat Mirror Material In Maxwell sachin.ostwal Maxwell Render 2 March 3rd, 2006 03:31 AM
