Old November 21st, 2006   #1 (permalink)
Philippines
Default HDRI in Environment Slot against HDRI in Dome Light
Perhaps some vray expert could explain to me the difference between the two specifically in using this in an exterior scene. Set up 1: Direct Light for sun and HDRI in the vray slot for the skylight. Set Up 2: Direct Light for sun and dome light with HDRI for the skylight then vray environment black color.
Is there any difference in terms of quality and render time? It seems to me that they are just about the same. Perhaps not?
TIA
Razorback is offline
Old November 22nd, 2006   #2 (permalink)
Philippines
Default Re: HDRI in Environment Slot against HDRI in Dome Light
Anyone would want to give some insight? Got 62 views but no comment or ideas?
Old November 24th, 2006   #3 (permalink)
Philippines
Old November 25th, 2006   #4 (permalink)
crazy homeless guy's Avatar
Name: travis schmiesing
try the chaos group forums.
travis schmiesing
Old November 25th, 2006   #5 (permalink)
Rick Eloy's Avatar
AFAIK, the dome light is another way of doing the same thing environment does, except you have more control over angles and power without having to go to the render dialog every 5 minutes. It acts as a light AND produces photons, meaning you have caustics. Another great thing is that you can rotate it at will to produce different effects without messing with the hdri map, making it (for me, at least) easier to set up a scene. Just keep in mind that when you have a dome light, you don't need to turn the environment on, which would be an overkill.
Rick Eloy
Rick Eloy is offline
Old November 25th, 2006   #6 (permalink)
Christopher Nichols's Avatar
The dome light is a LOT more powerful when doing HDRI lighting. Mainly because it is highly adaptive in its ray casting where the light intensity is very high, such as from light sources. This means that you can easily get sharp shadows from a Domelight when it was virtually impossible to get any from when in the environment. In fact, I don't know of any other rendering engine that can get as accurate a lighting from an HDRI than Vray using the domelight.
Christopher P Nichols
Old November 25th, 2006   #7 (permalink)
Philippines
Thanks a lot Chris and Rick.
Vray dome light problem neba77 VRay Render 12 June 25th, 2008 09:16 AM
Material and Light tests. yog Maxwell Render 9 May 3rd, 2006 08:28 AM
how does vray dome light work gvisual2005@yahoo.com.sg VRay Render 3 February 27th, 2006 03:13 PM
Animating environment light! aflack 3ds Max 1 January 27th, 2006 05:48 AM
