Hey Superdave,
To check if RAM is an issue open up your task manager (Right click on the clock in the lower left and go to the Performance tab). Start your rendering process and observer the MEM usage box. Compare this with Total Physical Memory and you will be able to detemine if you are paging to disk (ie you have run out of RAM) If this is the case either optimize your model or raytace settings or get more RAM.
Jeff Mottle
CGarchitect.com
