Old November 22nd, 2006   #1 (permalink)
United_States  Send a message via Yahoo to cakewalkr7
Default curved edges
I know this particular image isn't an arch viz type render, but I'm just trying to work on learning more about modeling in max. In this image, my main concern is how to make the edges curve nice and smooth? I've chamfered the edges a number of times, but you can clearly see the subdivisons. Is there a better way to create smooth curved edges? Thanks.
cakewalkr7 is offline
Old November 22nd, 2006   #2 (permalink)
Default Re: curved edges
try the subdivision modifier then add the relax modifier several times.
ipxstudios is offline
Old November 22nd, 2006   #3 (permalink)
Malaysia
From the looks of it u just gotta select all the polygons, go to 'polygon properties' and click on the autosmooth button (under smoothing groups). this will smoothen out the object without adding any faces.
bijoy is offline
Old November 23rd, 2006   #4 (permalink)
alikashan's Avatar
Pakistan  Send a message via MSN to alikashan Send a message via Yahoo to alikashan Send a message via Skype™ to alikashan
Thumbs up Re: curved edges
or you can add turbosmooth modifier to your model if it has proper divisions.
Ali Kashan
Stranger than LIfe......... but Still Learning
alikashan is offline
Old November 23rd, 2006   #5 (permalink)
anvaraziz's Avatar
try smoothing groups...
www.mukks.com
anvaraziz is offline
Old November 23rd, 2006   #6 (permalink)
FlytE's Avatar
Name: Andy Pennington
Scotland
add a 'smooth' modifier. Always meshsmooth as well but i dont find that as good - too powerful :P
"How many polygons does the real world push?"
FlytE is offline
Old November 23rd, 2006   #7 (permalink)
Thanks Bijoy, autosmooth worked great! I tried the turbo smooth earlier and also the mesh smooth. TS was too drastic with only 1 iteration so that didn't work too well. The mesh smooth worked a little, but the autosmooth really seemed to be what I needed.
Curved Walls drvox 3ds Max 4 October 5th, 2006 08:21 PM
making all slab edges plumb RAYMOND AutoCAD/AutoCAD Architecture 0 August 16th, 2006 05:39 PM
Metal Texturing & Worn/Polished edges Ealiom 3ds Max 1 May 24th, 2006 02:10 PM
rounded edges on models wizuby 3ds Max 6 July 27th, 2005 11:45 AM
Making edges visible rayray 3ds Max 6 February 20th, 2005 08:51 PM
