Old May 8th, 2008   #8 (permalink)
Bwana Kahawa
Bwana Kahawa's Avatar
England
Default Re: Amer Abidi - WIP
Wow Amir - if you pull that off it sounds fantastic. And a refreshing break from the norm of usual arch viz walkthroughs.
You'll have to make sure you create something that you can still use if time catches up with you though - but I guess if you make sure that the actual rendered footage of the building is completed first, then it won't matter so much if there isn't time to film the rest.
Can't wait to see it!
Bwana Kahawa is offline   Reply With Quote
