Old November 23rd, 2006   #1 (permalink)
Default 64 Bit backward compatibilty??
just crossed my thoughts...
when we upgrade to 64 bit etc and save a max file in 64 bit, or a CAD file or even more basic a word / excel file will i be able to send the file to someone else who is running 32 bit and will they be able open it?? i'm guessing not.
How about being able to back save to 32 bit file types as an option in the software... in a similar way that AutoCAD allows you to save backwards to 2004 format or 2000 format etc.
James
JamesTaylor is offline
Old November 23rd, 2006   #2 (permalink)
wda
wda's Avatar
Name: William Alexander
Default Re: 64 Bit backward compatibilty??
We just upgraded workstations and render farm to XP pro 64. All 32 bit applications, MAX, Modo, PSD, C4D.....get installed in a 32 bit programs folder to be run as 32 bit applications. We needed access to full 4 gig of ram...oh boy do we need it.
We don't have any "64 bit" applications at this time so everything runs just fine with the "coward's" who aren't ready to risk going 64 bit at this moment, systems. 64 Bit and 32bit "applications" and compatibility may or maynot be a problem in the future, but I'm not a programer by any stretch of the imagination
WDA
wda is offline
Old November 23rd, 2006   #3 (permalink)
I was told that stuff done in Max9 64 can be opened in Max9 32, assuming you have enough ram -if your Max9 64 scene uses 8GB, then it won't open in a 32-bit session. I'm looking forward to getting some definitive answers when we test a new 64-bit workstation our group just got.
DavidR is offline
Old November 29th, 2006   #4 (permalink)
its sounds as if its going to be effected more by the individual software packages and how they have been updated as opposed to a 64bit v 32bit issue.
Also, how about drivers for scanners / printers etc. will these have to upgraded to a 64bit version or can they still run 32Bit?
windows 64 crazy homeless guy Hardware and Technical Discusions 19 July 27th, 2006 01:36 AM
autocad 2007 and my 64 bit system 3dsmaxed AutoCAD/AutoCAD Architecture 2 April 29th, 2006 10:53 PM
lightscape and windows 64 bit d7man2000 Lightscape 2 November 25th, 2005 05:42 AM
AMd 3200+ vs the new p4 64 bit... 3dsmaxed Hardware and Technical Discusions 3 August 11th, 2005 05:52 AM
will my 64 bit system support the following haneet khanna Hardware and Technical Discusions 12 June 12th, 2005 10:08 PM
