Thread: adjast colors
Old May 8th, 2008   #2 (permalink)
Maxer
Maxer's Avatar
Default Re: adjast colors
The colors of objects are going to be affected by your lighting especially if you’re using a GI render engine. If you are using a GI engine like MR or Vray then the colors of objects in your scene are all going to be a little different from what you see in your material editor due to lights effect on the object and the color pollution caused by all the different materials in a scene. For instance your client may want a pure white wall, but if you look around at any white wall you'll notice it's not truly white because colors around it and even the light is causing it to look more grey or tan. There is no easy answer; you will just need to experiment.
“There is no spoon”
Maxer is offline   Reply With Quote
