Old May 8th, 2008   #11 (permalink)
CHE
CHE's Avatar
United_States  Send a message via MSN to CHE
Default Re: ArchViz - office building exterior
I haven't tried exporting from Max to Modo with the new FBX file format. I know you can't do that with previous 3dsmax versions. However, if you are looking for a camera match/tracker solution for Modo then make sure to check these guys out:
Quote from ssonic :[HR]A full SynthEyes/Modo exporter is now available, see
http://www.ssontech.com
Handles various scene types, exports camera/object path, tracker locations, meshes, lights to modo.
-Russ[HR]
CHE is offline   Reply With Quote
