Re: Help with animation parameter.
The problem is the object is scaled over the 90 frames also. Im using animation because I need to scale the object as it repeats along the spline.
Its actually for a train track seen from above that becomes smaller as it goes along. This isnt as easy as it sounds, The ties have to get closer together, scale down and follow the spline.
Any ideas?
