Old July 13th, 2002   #5 (permalink)
Ismael
Nisus,
Under Customize\Preferences\Gamma check if you have Enable Gamma Correction turned on. You can turn it on and control "Reflectance" as viewed on the Material Editor for all your bitmaps by changing the Input Gamma level. Perhaps you won't need to Radiosity Override but the solid colors. It is like teaching VIZ how to see (....). Of course, the brightness of output images is controlled by the Output Gamma value.
Ismael Orozco (Chico)
Ismael is offline   Reply With Quote
