Old May 8th, 2008   #10 (permalink)
shaneis
shaneis's Avatar
Default Re: Server Ram Vs Desktop Ram
Originally Posted by Rconce01 View Post
Ok this is what i bought for $180 (SERVER RAM)
Kingston 4GB (2 x 2GB) 240-Pin DDR2 FB-DIMM DDR2 667 (PC2 5300) ECC Fully Buffered Dual Channel Kit Server Memory Model KVR667D2D4F5K2/4G - Retail Item #: N82E16820134327 http://www.newegg.com/Product/Produc...82E16820134327
This is the same Ram except it is (DESKTOP RAM) and half the price
Kingston 4GB (2 x 2GB) 240-Pin DDR2 SDRAM DDR2 667 (PC2 5300) Dual Channel Kit Desktop Memory Model KVR667D2N5K2/4G - Retail
http://www.newegg.com/Product/Produc...82E16820134193
Now the original Ram is what dell put in there
Samsung 2GB, DDR2 SDRAM FBD Memory, 667MHz
So far this is what i can conclude the original one appears to be fully buffered hence the description "FBD memory" the fist server type memory is also fully buffered but the one right after "the cheaper one appears to not be fully buffered."
Thanks for that, if you want to match your RAM as closely as possible, you will need to use the more expensive option. Main difference being the ECC - Error Correction Code. As ECC RAM stores/checks/passes data it is a wee bit slower, but error free. Here's a link that will list Kingston RAM modules that are 100% guaranteed compatibility with your T5400. http://www.ramcity.com.au/system/42378.htm When replacing the modules, you'll see four "slots" to place the RAM, hopefully they're colour-coded for you. If so, place the Samsung RAM in the first colour, and the new RAM in the second colour. If they aren't coloured, imagine they are numbered left to right...1/2/3/4. Insert the RAM like this, Samsung modules in 1/3, new modules in 2/4. G'luck, S.
shaneis is offline   Reply With Quote
