Old May 14th, 2008   #5 (permalink)
WAcky
WAcky's Avatar
Default Re: Treestorm - Replacing sub objects
Select your tree
Click adjust in the modify rollout
Check the UV box that correspondes with the Leaf parameters
Click Sub-Objects
Start off with 1 (drag the slider across)
Click use plates
Now setup your plates
The three will now detach from the leaves
Apply a texture to the leaves!
WAcky is offline   Reply With Quote
